Looking For .250 chain gears
Discussion in 'Buy, Sell and Trade' started by ZARUBA1987, Feb 3, 2019.
  1. ZARUBA1987
    ZARUBA1987 Well-Known Member
    Tarkington Tx
    So I had .1227 scale chain from servo to rudder it did work but I was worried that it may be to light weight. So my Duca D Acosta kit from strike had .250 gears and chain in the kit. So I borrowed them and install in the Doria. I would like to find replacement gears. the chain is easy to find but the gear for the rudder has an 1/8 bore hole and a 440 set screw. I took a few photos. Let me know thanks DC6DBEEB-9FC7-4BF0-8581-0E0F9A7489CE.jpeg A1379F86-19CF-4ABA-8678-C608E7794C13.jpeg 6B856C5E-8235-4DA5-B5FD-1C91E5EFD9B8.jpeg
  2. GregMcFadden
    Stephen made them custom. Can get equivalent with a little work from servocity and McMaster if he has boxed them up by now.
  3. ZARUBA1987
    Tarkington Tx
    I will emailing Stephen and check. I checked out servocity and the smallest is about 1 1/2” OD then you still have to mount it on a hub for a 1/8 bore. It gets tight in the stern sometimes.
  4. bsgkid117
